I've read a bunch of threads and I just don't understand FPS, I-Frame and key.
I understand the frame rate (FPS) can be set at the camera as well as in BI (Cam properties -> Video -> Max. Rate), but I can't find where to set the i-frame.
Then I've read that I should set the i-frame so they key (which I think is the ration of FPS to i-frame) is 1.0 -- but I have no idea where to set the i-frame.
Then I read that the i-frame should be much much higher.
This all started for me because one of my cameras (371 Park lot) shows a totally gray, washed-out king of look upon playback.
Could someone please take a look at my status and advise how to improve performance?
Thank you!
Thank you!
