Trouble with network storage after reboot
TuckNTruck
Aug 16, 2022
89
139
NC
I've got my Aux 1 folder set to a network folder on a different PC in my house. I only use this for long term storage of clips I manually save. Nothing happens on this drive automatically.
Recently Windows did a big update or something (the reboot process took 15+ minutes and gave me a big welcome to windows screen after it finally updated/restarted).
Now whenever I restart the PC, BI says NAS location can't be reached. When I try to access the network storage folder from file explorer it asks for my credentials, but won't accept any the username/password for any of my machines.
Once I go to Network Connections and disable/enable the ethernet connection on my BI PC (the one that did the windows update), everything works fine. I can access the network folder without entering credentials and BI sees it without having to do anything there either. Next reboot, I have to disable/enable the ethernet connection again. The internet connection works fine before the disable/enable. It appears to just be a LAN issue?
It's clearly not a BI problem since I can't access the network folder in File Explorer either, so is this is bug with a windows update or am I missing something obvious?
Insure that the Windows Update did not change your NIC's network properties from "Private" to "Public."
Although I don't see how this would cause your particular issue but an update has been changing the network properties and causing other network issues for many people. :cool:
Yeah, it did change it. First time after update, that entire page was different and didn't even let me select private/public. After disable/enable cycle, those options opened up so I could put it back to private. Works fine until next reboot when another disable/enable cycle is required. There are a few tutorials on youtube about this or similar issues after the update and I've followed them all the way to resetting network adapters and reinstalling drivers etc. No change. I guess I need to look into rolling back to a previous windows version if that's even an option. Very frustrating to have a nice problem-free system running for a long time only to have a windows update mess it up.
Reactions: TonyR
Well, fingers crossed but it looks like I got it resolved. I was fumbling around in some windows security/firewall stuff and noticed it was saying I needed to verify login details for my microsoft/windows account. It sent a code to my email, plugged that into the box, it restarted and problem is solved. So I still don't understand why it acted the way it did, because it seems like resetting the ethernet adapter shouldn't bypass a missing account verification, but whatever. I've rebooted several times and it's working as it should again.
