Make your life easy. Buy an ASUS router and setup openvpnThanks for your reply back. I am not sure about port forwarded to the new ip address. Yes the router has new wan ip address and I also see DNS address in the router.
Please how can I setup a vpn solution
Thanking you in advance.
ASUS provides a free ddns too..If you have a new WAN IP address then you need a DDNS soultion so when your ISP changes your external IP address your system keeps track of the new IP address and changes accordingly.
Read VPN Primer for Noobs for information about VPN setup,
DDNS explanation Need to Get to Your Computer Remotely? Use a DDNS Service
Do you know any router that support VPN?.
I am very skeptical I am not sure if it is easy to do the configuration
Thank you so much. I will be leaving morocco next Monday. Once back to Toronto I will search for router and I will do alot of reading how to setup a camera. Once back to morocco I will try to configure it. I will keep in touch with you. Right now what I did I scan the QR code and I can see the camera on my phone. Only my phone can view the camera. The other members of my family can not.RT-AC53 | Networking | ASUS Global for example but search their product page for one you like and can afford and look at their features. It usually states VPN server on the page somewhere.
See if there is anything like this inside router setupI am going to try to get Noip. I reviewed the documentation for port forwarding and Tenda D305 is not listed as router. How can I do the port forwarding
Please help me I have only one day to try to figure out the camera
Also install teamviewer on that pc so can access from afarI am going to try to get Noip. I reviewed the documentation for port forwarding and Tenda D305 is not listed as router. How can I do the port forwarding
| Server Name | External Port Start | External Port End | Protocol | Internal Port Start | Internal Port End | Server IP Address | WAN Interface | Remove |
| CAM | 8000 | 8000 | TCP/UDP | 8000 | 8000 | ppp0.1 | | |
| WhatsApp (1572056872) () | 49011 | 49011 | UDP | 49011 | 49011 | ppp0.1 | | |
| DIRECT_REVERSE_SERVER | 34001 | 34001 | TCP | 45739 | 45739 | ppp0.1 | |
This is what I have. My screenshot from Tenda. I deleted my ip address from screenshot
NAT -- Virtual Servers Setup
Virtual Server allows you to direct incoming traffic from WAN side (identified by Protocol and External port) to the Internal server with private IP address on the LAN side. The Internal port is required only if the external port needs to be converted to a different port number used by the server on the LAN side. A maximum 32 entries can be configured.
Server Name External Port Start External Port End Protocol Internal Port Start Internal Port End Server IP Address WAN Interface Remove CAM 8000 8000 TCP/UDP 8000 8000 ppp0.1 WhatsApp (1572056872) () 49011 49011 UDP 49011 49011 ppp0.1 DIRECT_REVERSE_SERVER 34001 34001 TCP 45739 45739 ppp0.1
