These are my 5442T-ZE at full zoom. Approximately 33 feet and 25 feet, respectively.
View attachment 158234View attachment 158235
Do you have a wide shot to show up the difference? I can't remember if you took a pic wide or not?
At full retract? I don't think so, but I can look.Do you have a wide shot to show up the difference? I can't remember if you took a pic wide or not?
How does that camera perform at night? I was under the impression you didn't want a 4MP camera that is anything smaller than a 1/1.8" sensor.If you are looking for a small PTZ, I would look into the SD4A425DB-HNY.
It could be better, but it could be worse. I haven't had much opportunity to track anyone when it gets dark. Supplemental light is definitely a plus. Unfortunately I can't add extra light much more than on my property.How does that camera perform at night? I was under the impression you didn't want a 4MP camera that is anything smaller than a 1/1.8" sensor.
But yes if size isn't a factor, then you would want to get the a PTZ on the recommended MP/sensor ratio.
On one of my entry doors I was thinking I could go with a 3.6mm. In my photo there is alot of extra stuff in the picture that my 2.8 Lorex is showing. The PTZ cam will be about 25' to the left of this camera so it will be picking up alot of the front including the extra in my photo. View attachment 158516
Quite helpful. I am more and more inclined to try 3.6 instead of 2.8. Might even get a 6mm for the long side of the house.This is obviously at my front door. The yard is a 5442 2.8mm, the view from next to the door is a 5MP 2.8mm wedge, and the above door view is a 5442 3.6mm.
That's quite a difference. What are the specs of your new 3.6mm camera? I have read here in the forums that depending on specs some 3.6mm cameras won't make a big difference as far as focal lengths compared to a 2.8mm.I had some weather come through the other day that took out the 2.8mm over my backyard. I wasn't sure what the issue was so I went ahead and replaced it with the 3.6mm that will assume its duty when I move it down to deck level. I could have lived without a camera there but I really wanted to be able to keep an eye on the deck as it is being built.
I realize the scene is not the same, but here are some shots to show the difference between the two focal lengths.
View attachment 159046View attachment 159045
Straight swap from a 2.8mm 5442 to a 3.6mm 5442.Well for now I ordered the three
