VPN Primer for Noobs
  • Total voters
    869
By the way, which of the vpn protocols are considered to be fast?
I'm using an openVPN and the speed is dramatically dropped down in compare to not having a vpn.
i get about 1 Giga bit/sec (from ISP) on each side (client and remote server) and when i connect the client via a vpn, the speed is only ~20 Mb/s .
Wireguard is probably the "lightest" and therefore fastest.
Reactions: Ollie
Yea, an understanding is always a good thing. step by step instructions might get you there but you won't know where you are.
Have you looked into Wireguard? Not sure how it works on IpnSense, but it was straight forward when I used Home Assistant and the Wireguard add-on, it will generate the key and it presented the QRcode on screen, just used the iPhone cam to capture the QRcode and way you go.
Reactions: Sparkey
I'm going to look into Wire Guard. OpenVPN gives you a QR code also and I took a picture of it with my iPhone and it did nothing. The OpenVPN client doesn't give you the option to use the code.
If the Wireguard add-in on OpnSense doesn't give you a QR code, you can plug in the information into a field on Wireguard's website to generate it:
Edit: The geek that I am, I was curious on how to do Wiregard on OpnSense and found the youtube video below, you probably already viewed it. I found his instructions and pace great.
Reactions: Sparkey
I cannot for the life of me figure out how to transfer the client file to my iPhone. All the instructions I can find tell me to click button s that don't exist or they don't bother to tell where these buttons are. Can someone please tell me how to go about getting the client file from my computer to the OpenVPN client on my iPhone?
TIA
OK, I emailed the client file to my phone and was able to get it installed in the VPN Client but there's still something wrong because I'm getting pages of error messages when I attempt to connect from my iPhone.
Can someone direct me to instructions on how to set up OpenVPN? At this point it looks like the instructions I followed earlier don't work. :(
Did you ever get this to work? The email doesn't always work on an iPhone. I uploaded my file to Icloud then opened the Files app on the phone. I clicked on the file, opened it in OpenVPN Connect then just had to enter my username and password.
I'm having a problem I might ask about here if I can't figure it out. Saw this while I was looking for a similar problem.
If you have local access to the VPN server, then you should download the key directly from the server to each device you eventually want to connect remotely. This is the easiest and most secure way to pass keys. For example, I use pfSense, so I just open the psSense GUI on my device (phone, tablet, computer, etc), browse to the VPN section, and download the key directly to my device. I can then use that key during the setup of the VPN connection without having to email the key or upload it to a cloud server.
Just be aware that most email and online storage is not encrypted and therefore your key could be exposed. Now I will admit that the odds of someone getting an encryption key AND having the knowledge to be able to access your VPN connection is pretty small. But if you have passed that information along via the same unsecure method (a different email for example), then it might not be such long odds.
I have an Asus X8 router and have already setup the VPN on it
Is the original post still pretty up to date?
I wanted to get everything setup & secure for my new camera network
u running open vpn or wireguard
I set it up using Wireguard
My new router VPN seems to be working well.
So should I still follow everything in the first post to finish setting my network up to get ready for this new camera system?
I also plan on following this walk-thru to secure my camera system & network:
Reactions: flynreelow
Hey guys, recently reinstalled Wiregaurd on my Asus Router (was having some difficulties with my Pi).
I can't seem to log in to the BlueIris app when connected via VPN. Get a "Check server reachability" error? Tried looking it up online, but can't find any info on that error.
Should also add, I tried uninstalling and reinstalling the BlueIris app to start from scratch. Same issue after adding the server via the QR code.
Have you ever had remote access to blue Iris using Wireguard when VPN is running on the Blue Iris PC? Is VPN needed? Maybe Wireguard works in a similar way to ZeroTier. As I recall, VPN must be turned off to stop it screwing up the routing in ZeroTier’s private network.
Decided to start working again. No idea why.
It's because you were getting very close to the root problem and it didn't want you to discover it so it can do it to you again.
  • Haha
Reactions: samplenhold
