L llarsx Getting the hang of it May 7, 2018 222 17 Jan 15, 2023 #1 I have a Hikvision ip camera, mostly used to catch my fantastic seaside view. I have seen blue iris mentioned everywhere, but what is it and should I use it?
IAmATeaf Known around here Jan 13, 2019 3,456 3,425 United Kingdom Jan 15, 2023 #2 BI is an NVR which runs on a Windows 10/11 desktop used to record and raise alerts based upon configuration. Why do you think you want or need BI, what is missing or doesn’t work with your current setup ?
wittaj IPCT Contributor Apr 28, 2019 34,533 65,749 USA Jan 15, 2023 #4 BI is a VMS like an NVR, so if you are fine with just the cameras with no VMS system, continue on! But if you get to the point that you are thinking of an NVR, then consider BI. Reactions: llarsx
L llarsx Getting the hang of it May 7, 2018 222 17 Jan 16, 2023 #5 wittaj said: BI is a VMS like an NVR, so if you are fine with just the cameras with no VMS system, continue on! But if you get to the point that you are thinking of an NVR, then consider BI. Click to expand... Thanks.
