- May 18, 2017
- 60
- 13
Is there a list of scripts that can be used in the BI PTZ Preset "On Call", MQTT line? Or maybe a Do Command? I've copied/pasted a script for day/night control from others but don't inherently understand scripts myself.
I have a 2017 Dahua IPC-HFW4431R-Z (zoom only) without the PTZ/Preset function in the UI so looking for an alternative way to adjust the zoom using BI presets. Unless I'm missing it (and that's quite likely!) I don't see a way in BI to set a zoom preset and I assume this must be done in the camera UI like other modern PTZ's.
Thank you.
Thank you.
