Why is power consumption an issue?
Rickoo
Nov 16, 2019
206
72
I've been reading threads regarding concerns about power consumption. Why is this such an issue? Is it long term cost? Heat?
Maybe both. The overall idea is efficiency.
Hi @Rickoo
As members pickup more cameras for their home setups.. it starts to add up, especially with those nice PoE+ PTZ cameras we all want to deploy..... ;-)
So PoE switches have power limits, and there will be loss of power on the cables, and while each individual camera does not consume a lot of power it does add up - and ideally you do want to have the equipment be reliable - thus lower power use = lower heat = in theory more reliable. Also we do need to do power calculations to ensure which ever PoE switch ( or NVR w/PoE ports ) can handle the cameras and other POE devices attached to the switch.
Yes, probably less of an issue for most home users - and certainly a greater issue for a large setup. ( example companies with a lot of POE equipment - like phones, as the switches are often in datacenter areas which are climate controlled - so more power consumed, higher heat generated - more AC costs )
