Will this work on this Amcrest nvr
Firefighter
Jun 18, 2014
253
344
Alright so I'm making a final decision. Based on my recent threads, just going with the 4k ip amcrest because its an indoor office environment.
Heres the question, Can I split the system with a poe switch on the other side of the building if I get this nvr that has individual ports?
So, this 32ch nvr has 16 poe ports. Great, I can just use those for one side of the office.
Can I then have a poe switch on the other side, and feed those x amount of cams into one single port back into the nvr?
Does every port only support one single camera? Because if so, then I need to get the nvr with no poe and one single input and I can add the poe switches.
Just wouldn't mind having 16 built in poe.
Here's the diagram of what I'm planning on. It would make wiring so much easier dealing with 30,000 sq ft of office space...
Here's the nvr in question.
If not, then I'll need this nvr and poe switches
Which would mean i network it like so......
I have an Amcrest Nvr 4108
I can run 8 cameras. i have some on the Nvr and some on a Poe switch
you just go to the Camera tab and do a device search and it will populate the results of what it can find......
Then I think you can use the Admins Password to enable the camera with the IP of the device found.
The Nvr's like to assign the NVR's Admin Password to for cameras GUI password
