I am attempting to log into my NVR via the DMSS app and it's not taking the IP when I am attempting to add it as a local device. Do I need to create an online account to have the app work? I know in older versions this was not required.
why cant you use the DMSS locally? do you VPN into your DMSS app when not home?Amcrest View Pro 2 will work on your local LAN. That's what I use at home and DMSS when away from home.
Enter the IP manually (button at the bottom of the page).Still will not find my nvr ip even when logged into openvpn on my phone.
Yeah, that’s what I’ve tried multiple times. Didn’t have this issue with the old app.Enter the IP manually (button at the bottom of the page).
Possibly your OpenVPN is set to your home LAN range only without allowing mDNS scanning.
