Send Pushover notifications with pictures and hyperlinks
Let's try these two things first:
  1. What's the typical size of your camera's alert JPGs? If over 2.5MB, then they are rejected by the Pushover API. If this appears to be the issue, then the solution might be my pushover_resize script.
  2. If not #1, then try checking setting 'Wait for process to complete' on the 'Run a program' action in the 'On alert' action set.
Ok - just confirmed through multiple alerts that selecting the setting 'Wait for process to complete' did not resolve my issue.
Check out these posts for background on Blue Iris' short-lived temporary JPGs:
first
second
They matter if you are NOT saving high-res JPGs or creating AI markup images.
Thanks - I am creating high res JPGs and I am creating the AI markup images, so seems that doesn't apply to me then?
Ugh. I've just parsed your command syntax. Everything appears to be in order.
Correct.
I looked at the first post that you linked (here) where the user was having a similar issue, but I don't think that applies, since I have the defaults checked on the record tab of this particular camera (and all my other cameras sync with this one). Please let me know if that's not correct though.
Try my 'msg.exe' trick... Insert the following 'Run a program' action before the pushover curl action.
This should pop up a window that shows the expanded macros, so that you can confirm that the JPG path in the curl command is as you expect.
Here's the 'Parameters' field text * /TIME:5 DB=&ALERT_DB, PATH=&ALERT_PATH
Increase the TIME value if you want the window to stay open longer.
Reactions: JNDATHP
Thanks - just tested and it seems to be coming back correctly
When I look in the alerts folder, the jpg file in this PATH is the correct JPG.
Very good.
As an experiment, you might try removing the argument --form-string "device="%998"
Maybe it's expanding to a funky value that's screwing up the command syntax.
EDIT - you can inspect this macro in the msg.exe command as well.
Reactions: TonyR
Very good.
Bingo! that was it! I removed that and it works.
I will do some more testing later tonight as to what the issue actually was, but for now I'm just glad it's working. Thanks so much!
Reactions: jaydeel
Well I broke down and tried something new.
I used the description at the beginning of this post and used word pad to paste my " parameters" string together with my API and USER key, and Device name.
I put the App on my iphone.
I also did a FAFO with the Windows App on my desktop PC, ,,,, unneeded as i found out from @wittaj.
Anyway, I hit the lightning bolt test icon, and it sent a notification to my phone.
Yippee.
Im running CP AI on a couple cams. so it asked for an AI alert type, so I put Car, Person
I'm just trying it out on the LPR cam 1st.
I get about 500 alerts or more a day on the counter in the BI mobile app. As a commercial vehicle operator, I cannot have my phone blowing up with pushover notifications out the ass.
Even if I get the notification, I cannot use my phone to retrieve it while in motion. So I have all notifications silenced on my phone.
FFS my old Nightowl DVR, was horrid, When it did work ( the App) I think we bogged down the local Verizon tower with 100 notifications to 2 phones every time the wind blew. I think they fuckin blocked it after awhile as a DDoS Attack LOL.
The Amcrest NVR was no better. I had to turn off notifications because my phone was blowing up all day.
Hopefully this will quell the clutter.
thanks again
New Heartbeats for Pushover
If you use Pushover for Teams, then you might be interested in the following new feature that was Implemented at the request of a user.
What I really need is a monitor on the Pushover messages that alerts me when one hasn't been received for a certain number of hours. A heartbeat monitor.
I emailed the developer about the future availability for individual accounts. The reply…
… it is likely going to remain a teams-only feature so you would need to subscribe to Pushover for Teams to take advantage of it at this time.
I have been using BlueIris and Pushover for a couple years now without any issues.
Yesterday all my pushover message from BlueIris stopped. Only change I have made recently was over a week ago when I move my BlueIris install to a new computer running Windows 11. All went well until yesterday.
Here is the syntax that I have been using since the start.
-s --form-string "token=MYTOKEN" --form-string "user=MYUSERID" --form-string "message=<b>&CAM</b> &MEMO <a href='&WAN/alerts/&ALERT_DB?fulljpeg'>Hi-Res</a> <a href='&WAN/ui3.htm?rec=&ALERT_DB'>UI3</a>" --form-string "html=1" --form-string "device=MYDEVICE" --form-string "sound=Clue" -F "attachment=@D:\BlueIris\Alerts\&ALERT_PATH"
Does anyone see any issues as to why this would have stopped working?
I've not run into this issue before.
Suggest logging on to your Pushover dashboard
https://pushover.net/
Then confirm your devices (scroll down the dashboard page)
and licenses https://pushover.net/licensing
EDIT: If everything looks okay on the dashboard, then try sending a test notification from the Pushover dashboard, and from cmd.exe (see post #1).
Keep in mind that the Blue Iris macros will not expand unless the command is issued from a Blue Iris action.
Yea me too, stopped a few days ago.
I worked out it was because I renamed the share for the attachment location. Make sure your file paths for alerts are correct.
Try remove '-F "attachment=@D:\BlueIris\Alerts\&ALERT_PATH' and see if you get the alert then.
I just started testing this since I cant get sms messages on an alert anymore. As it is now I get the alert notifications, but the links to the jpeg and UI does not work. I should clarify that I sit behind a VPN client setut up on the router so that the address that is gotten from &WAN would be incorrect - it returns the address of the VPN. Also I try not to use port forwarding. I do have a ddns set up. What to I need to do to get the links for the jpeg and ui to work correctly?
Try entering your ddns address in the WAN field on the Settings > 'Web server' tab.
If that doesn't work, please provide the REDACTED syntax you are using in the Run a program Action 'Parameters' field.
I changed the Web Server to my ddns. It didn't help. Here is the parameter in the alert box:
-s --form-string "token=xxxxxxxxxxxxxxxxxxxxxxxx" --form-string "xxxxxxxxxxxxxxxxxxxxxxxxxxxx" --form-string "message=<b>&CAM</b> &MEMO <a href='&WAN/alerts/&ALERT_DB?fulljpeg'>Hi-Res</a> <a href='&WAN/ui3.htm?rec=&ALERT_DB'>UI3</a>" --form-string "html=1" --form-string "device=YOUR_PUSHOVER_DEVICE_NAME(S)_HERE" --form-string "sound=YOUR_PUSHOVER_SOUND_HERE" -F "attachment=@I:\Alerts\&ALERT_PATH"
My system is set up with BlueIris on the D drive. All the date is on the I drive -- so the jpgs are on I:/Alerts.
